  4. 求教:Laval 喷管模拟产生激波边界条件设置问题
9 帖子 2 发布者 7.2k 浏览
    yingqing
    想要设置喷管,入口总压102387.1Pa,出口静压42449.07Pa, 入口温度294.45K。采用kOmegaSST湍流模型。但是运行报告湍流边界条件设置有问题。改了好几次都不行,希望各位老师,能帮我看一下,看看是哪里设置存在问题。以下是我的初始条件:
    U T p omega nut Ma k alphat
    运行报错结果:
    tsing@tsing:~/OpenFOAM/tsing-v2206/run/EosNozzlePerfect$ rhoPimpleFoam
    |  \\    /   O peration     | Version:  2206                                  |
    Build  : _76d719d1e6-20220624 OPENFOAM=2206 version=v2206
    Arch   : "LSB;label=32;scalar=64"
    Exec   : rhoPimpleFoam
    Date   : Feb 24 2025
    Time   : 18:29:00
    Host   : tsing
    PID    : 218467
    I/O    : uncollated
    Case   : /home/tsing/OpenFOAM/tsing-v2206/run/EosNozzlePerfect
    nProcs : 1
    trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
    fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
    Create time
    Create mesh for time = 0
    PIMPLE: Operating solver in PISO mode
        type            heRhoThermo;
        mixture         pureMixture;
        transport       const;
        thermo          hConst;
        equationOfState perfectGas;
        specie          specie;
    Reading field U
    Creating turbulence model
    Selecting turbulence model type RAS
    Selecting RAS turbulence model kOmegaSST
    Selecting patchDistMethod meshWave
    RAS
        RASModel        kOmegaSST;
        turbulence      on;
        printCoeffs     on;
        alphaK1         0.85;
        alphaK2         1;
        alphaOmega1     0.5;
        alphaOmega2     0.856;
        gamma1          0.555556;
        gamma2          0.44;
        beta1           0.075;
        beta2           0.0828;
        betaStar        0.09;
        a1              0.31;
        b1              1;
        c1              10;
        F3              false;
        decayControl    false;
        kInf            0;
        omegaInf        0;
    Creating field dpdt
    Creating field kinetic energy K
    No MRF models present
    Courant Number mean: 4.30558e-05 max: 0.0192008
    Starting time loop
    Time = 5e-05
    PIMPLE: iteration 1
    diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
    DILUPBiCGStab:  Solving for Ux, Initial residual = 1, Final residual = 8.37036e-10, No Iterations 1
    DILUPBiCGStab:  Solving for Uy, Initial residual = 1, Final residual = 4.3098e-10, No Iterations 1
    DILUPBiCGStab:  Solving for e, Initial residual = 1, Final residual = 4.75567e-09, No Iterations 1
    GAMG:  Solving for p, Initial residual = 1, Final residual = 0.00613491, No Iterations 3
    GAMG:  Solving for p, Initial residual = 0.00680296, Final residual = 3.5161e-05, No Iterations 4
    time step continuity errors : sum local = 8.28493e-08, global = -7.8312e-09, cumulative = -7.8312e-09
    GAMG:  Solving for p, Initial residual = 0.147144, Final residual = 0.000685025, No Iterations 3
    GAMG:  Solving for p, Initial residual = 0.000646506, Final residual = 5.05846e-07, No Iterations 5
    time step continuity errors : sum local = 1.88756e-09, global = -4.94043e-10, cumulative = -8.32524e-09
    #2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
    #3  Foam::omegaWallFunctionFvPatchScalarField::calculate(Foam::turbulenceModel const&, Foam::List<double> const&, Foam::fvPatch const&, Foam::Field<double>&, Foam::Field<double>&) at ??:?
    #4  Foam::omegaWallFunctionFvPatchScalarField::calculateTurbulenceFields(Foam::turbulenceModel const&, Foam::Field<double>&, Foam::Field<double>&) at ??:?
    #5  Foam::omegaWallFunctionFvPatchScalarField::updateCoeffs() at ??:?
    #6  Foam::kOmegaSSTBase<Foam::eddyViscosity<Foam::RASModel<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > > > >::correct() at ??:?
    #7  ? in ~/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam
    #8  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
    #9  ? in ~/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam
    Floating point exception (core dumped)
    • 换一个湍流模型能收敛么
    • 用旧版本的能收敛么?比如OF9
    yingqing
    换成层流模型可以。但换成kEpsilon模型,也是在Epsilon壁面函数错误。输出结果如下所示。
        type            heRhoThermo;
        transport       const;
        thermo          hConst;
        specie          specie;
    Reading field U
    Selecting RAS turbulence model kEpsilon
    RAS
        RASModel        kEpsilon;
        turbulence      on;
        printCoeffs     on;
        Cmu             0.09;
        C1              1.44;
        C2              1.92;
        C3              0;
        sigmak          1;
        sigmaEps        1.3;
    Creating field dpdt
    Starting time loop
    Time = 5e-05
    PIMPLE: iteration 1
    smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 4.88632e-08, No Iterations 1
    smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 2.83045e-08, No Iterations 1
    smoothSolver:  Solving for e, Initial residual = 1, Final residual = 3.20771e-07, No Iterations 3
    GAMG:  Solving for p, Initial residual = 1, Final residual = 0.00612066, No Iterations 3
    GAMG:  Solving for p, Initial residual = 0.00680187, Final residual = 3.35179e-05, No Iterations 4
    time step continuity errors : sum local = 7.89239e-08, global = -7.08945e-09, cumulative = -7.08945e-09
    GAMG:  Solving for p, Initial residual = 0.147326, Final residual = 0.000684668, No Iterations 3
    GAMG:  Solving for p, Initial residual = 0.00064622, Final residual = 4.92284e-07, No Iterations 5
    time step continuity errors : sum local = 1.8365e-09, global = -5.67277e-10, cumulative = -7.65673e-09
    #3  Foam::epsilonWallFunctionFvPatchScalarField::calculate(Foam::turbulenceModel const&, Foam::List<double> const&, Foam::fvPatch const&, Foam::Field<double>&, Foam::Field<double>&) at ??:?
    #4  Foam::epsilonWallFunctionFvPatchScalarField::calculateTurbulenceFields(Foam::turbulenceModel const&, Foam::Field<double>&, Foam::Field<double>&) at ??:?
    #5  Foam::epsilonWallFunctionFvPatchScalarField::updateCoeffs() at ??:?
    #6  Foam::RASModels::kEpsilon<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correct() at ??:?
    这两个问题都出现在壁面函数上 目前智能判断到这里 OF9你有就试试
    yingqing
    OF9尝试了,还是避免函数有问题,结果如下:
        type            heRhoThermo;
        transport       const;
        thermo          hConst;
        specie          specie;
    Reading field U
    RAS
        model           kEpsilon;
        turbulence      on;
        printCoeffs     on;
        Cmu             0.09;
        C1              1.44;
        C2              1.92;
        C3              0;
        sigmak          1;
        sigmaEps        1.3;
    Creating thermophysical transport model
    Selecting thermophysical transport type RAS
    Selecting default RAS thermophysical transport model unityLewisEddyDiffusivity
    Creating field dpdt
    No fvModels present
    No fvConstraints present
    #3  Foam::nutkWallFunctionFvPatchScalarField::nut() const at ??:?
    #4  Foam::nutWallFunctionFvPatchScalarField::updateCoeffs() at ??:?
    #5  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::evaluate() in "/home/tsing/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam"
    #6  Foam::RASModels::kEpsilon<Foam::CompressibleMomentumTransportModel<Foam::dynamicTransportModel> >::correctNut() at ??:?
    #7  ? in "/home/tsing/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam"
    #8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #9  ? in "/home/tsing/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam"
    能公开就把算例网格处理到3万以下,上传我debug
    另外你可以看看这个 http://dyfluid.com/openfoam.html#laval
    yingqing
    网址上的案例看了,使用的是层流模型。我使用层流模型也可以跑通。但使用RAS模型加入壁面函数出问题,麻烦李老师给我看看,debug一下:xiexie:
    EosNozzleTestUpdate.zip
    rhoPimpleFoam_2.tar.xz
    yingqing
    李老师,感谢您的修改,对比后我发现我对fvsolutions的设置还不太明确。用您改后的案例,openfoamv9跑出来了,但用openfoam-v2206还是报原来的错误。目前,我准备尝试用clion调试找一下壁面函数中wallDist的问题
