  3. icoFoam运算出错
icoFoam运算出错
8 帖子 2 发布者 4.1k 浏览
    zzq704
    各位老师和同学,本人是打算用icoFoam运算一个从Icem里面转化来的网格,在使用icoFoam试运行的时候,出现了如下错误,第一步就出错了。请问是什么问题呢?Icem里面的网格包含Interface,在openFoam里面设置了cyclicAMI代替,我猜测是不是这一步出了问题,因为interface相邻面面积不一致,我看cyclicAMI介绍好像有说相邻面大小要一样。
    openFoam小白,还望各位赐教。:135:
        \\  /    A nd           | Version:  9
         \\/     M anipulation  |
    Build  : 9-710dba47639b
    Exec   : icoFoam
    Date   : Mar 22 2022
    Time   : 20:18:23
    Host   : "nm"
    PID    : 58789
    I/O    : uncollated
    Case   : /home/nm/OpenFOAM/nm/cavityceshi2/cavity
    nProcs : 1
    fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
    Create time
    Create mesh for time = 0
    Reading transportProperties
    Reading field p
    Reading field U
    AMI: Creating addressing and weights between 151 source faces and 134 target faces
    AMI: Patch source sum(weights) min/max/average = 0, 1, 0.841191
    AMI: Patch target sum(weights) min/max/average = 0, 1, 0.813281
    Starting time loop
    Time = 0.0005
    Courant Number mean: 0 max: 0
    smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 9.17761e-06, No Iterations 77
    smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 9.92611e-06, No Iterations 97
    smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 9.44364e-06, No Iterations 71
    #3  Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:?
    #4  ? in "/home/nm/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/bin/icoFoam"
    #5  ? in "/home/nm/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/bin/icoFoam"
    #6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #7  ? in "/home/nm/OpenFOAM/OpenFOAM-9/platforms/linux64GccDPInt32Opt/bin/icoFoam"
    浮点数例外 (核心已转储)
    nm@nm:~/OpenFOAM/nm/cavityceshi2/cavity$
    zzq704
    在 中回复了 zzq704 最后由 编辑
    大佬救命,搞不懂嘎
    @zzq704 感觉像是除以0了,你看看你边界条件都对么,以及网格什么样的
    zzq704
    感谢老师回复
    顺便问一下,cyclicAMI两个面,其面积是可以不等的吗,我在纠结是不是这里有问题导致的出错。例如是下图两个面。
    @zzq704 不可以 要相同
    zzq704
    那么如果我在icem里面画的网格,interface的两个面大小不相等,要导入到openFoam里面,有什么解决办法吗?
    @zzq704 可以把你第一个图的面,分割成3个面,中间的面不是cyclicAMI,上下的为cyclicAMI
    zzq704
    @李东岳 好的,谢谢李老师
