jet 的边界条件如何选择?
各位大佬,请问谁有经验处理过类似jet的boundary condition?
下图是使用incompressible solver后达到steady-state的速度场,现在因为其他原因,要使用comprenssible solver,但是使用相同的边界条件会导致计算发散。
目前的compressible solver 的边界条件如下
inlet { 特定profile } outlet { /*type pressureInletOutletVelocity; value uniform (0 0 0); inletValue uniform (0 0 0);*/ type inletOutlet; phi phi; inletValue $internalField; value $internalField; } walls { type noSlip; } }
压力场 internalField uniform 1e+05; boundaryField { inlet { type totalPressure; p0 $internalField; } outlet { type zeroGradient; } walls { type zeroGradient; } }
k dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.1; boundaryField { inlet { type turbulentIntensityKineticEnergyInlet; intensity 0.145; value $internalField; // placeholder } walls { type kqRWallFunction; value uniform 1; } outlet { type inletOutlet; inletValue uniform 0; value uniform 0; } }
epsilon boundaryField { inlet { type turbulentMixingLengthDissipationRateInlet; mixingLength 2.0e-5; value $internalField; } walls { type zeroGradient; } outlet { type inletOutlet; inletValue $internalField; value $internalField; } }
如果哪位大佬有相关经验,麻烦指点一下。谢谢
速度不是很高,但是gradient很大,速度的峰值在12m/s 左右,gradient在整个diameter 10% 左右就变为0了。
网格也不是很复杂,是一个圆柱,中间有加密的ogrid -
谢谢 我试试,刚才刚又试错了一下,看看修改以后如何
Courant Number mean: 0.0011211 max: 0.20004 Time = 0.0089 Solving 3-D cloud sprayCloud Cloud: sprayCloud Current number of parcels = 0 Current mass in system = 0 Linear momentum = (0 0 0) |Linear momentum| = 0 Linear kinetic energy = 0 model1: number of parcels added = 0 mass introduced = 0 model2: number of parcels added = 0 mass introduced = 0 model3: number of parcels added = 0 mass introduced = 0 model4: number of parcels added = 0 mass introduced = 0 model5: number of parcels added = 0 mass introduced = 0 model6: number of parcels added = 0 mass introduced = 0 model7: number of parcels added = 0 mass introduced = 0 model8: number of parcels added = 0 mass introduced = 0 model9: number of parcels added = 0 mass introduced = 0 model10: number of parcels added = 0 mass introduced = 0 model11: number of parcels added = 0 mass introduced = 0 model12: number of parcels added = 0 mass introduced = 0 model13: number of parcels added = 0 mass introduced = 0 model14: number of parcels added = 0 mass introduced = 0 model15: number of parcels added = 0 mass introduced = 0 model16: number of parcels added = 0 mass introduced = 0 model17: number of parcels added = 0 mass introduced = 0 model18: number of parcels added = 0 mass introduced = 0 model19: number of parcels added = 0 mass introduced = 0 model20: number of parcels added = 0 mass introduced = 0 model21: number of parcels added = 0 mass introduced = 0 model22: number of parcels added = 0 mass introduced = 0 model23: number of parcels added = 0 mass introduced = 0 model24: number of parcels added = 0 mass introduced = 0 model25: number of parcels added = 0 mass introduced = 0 model26: number of parcels added = 0 mass introduced = 0 model27: number of parcels added = 0 mass introduced = 0 model28: number of parcels added = 0 mass introduced = 0 model29: number of parcels added = 0 mass introduced = 0 model30: number of parcels added = 0 mass introduced = 0 model31: number of parcels added = 0 mass introduced = 0 Parcel fate (number, mass) : patch inlet - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch walls - escape = 0, 0 - stick = 0, 0 Parcel fate (number, mass) : patch outlet - escape = 0, 0 - stick = 0, 0 Temperature min/max = 0, 0 Mass transfer phase change = 0 D10, D32, Dmax (mu) = 0, 0, 0 Liquid penetration 95% mass (m) = 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 GAMG: Solving for Ux, Initial residual = 0.0037785, Final residual = 9.6735e-10, No Iterations 2 GAMG: Solving for Uy, Initial residual = 0.0037745, Final residual = 1.0196e-09, No Iterations 2 GAMG: Solving for Uz, Initial residual = 0.0052513, Final residual = 7.2493e-09, No Iterations 1 DILUPBiCG: Solving for H2O: solution singularity DILUPBiCG: Solving for h, Initial residual = 0.0041966, Final residual = 1.7553e-06, No Iterations 1 T gas min/max = 297.98, 298.06 GAMG: Solving for p, Initial residual = 0.0040789, Final residual = 8.4078e-08, No Iterations 17 GAMG: Solving for p, Initial residual = 8.4041e-08, Final residual = 6.0506e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 6.273e-11, global = -3.4834e-11, cumulative = -9.0638e-09 rho max/min : 1.1693 1.1679 GAMG: Solving for p, Initial residual = 1.8592e-05, Final residual = 6.078e-08, No Iterations 5 GAMG: Solving for p, Initial residual = 6.078e-08, Final residual = 3.4733e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 3.601e-11, global = -6.4427e-12, cumulative = -9.0703e-09 rho max/min : 1.1693 1.1679 GAMG: Solving for p, Initial residual = 7.8717e-07, Final residual = 5.5203e-08, No Iterations 2 GAMG: Solving for p, Initial residual = 5.5203e-08, Final residual = 3.6842e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 3.8197e-11, global = 2.3727e-12, cumulative = -9.0679e-09 rho max/min : 1.1693 1.1679 GAMG: Solving for epsilon, Initial residual = 1, Final residual = 7.3363e-15, No Iterations 1 bounding epsilon, min: -1.0372 max: 71109 average: 1.3751 GAMG: Solving for k, Initial residual = 0.01149, Final residual = 1.4722e-09, No Iterations 2 bounding k, min: -0.0028333 max: 4.2155 average: 0.095222 PIMPLE: iteration 2 GAMG: Solving for Ux, Initial residual = 0.82941, Final residual = 1.8962e-11, No Iterations 1 GAMG: Solving for Uy, Initial residual = 0.78244, Final residual = 3.1846e-10, No Iterations 1 GAMG: Solving for Uz, Initial residual = 0.77963, Final residual = 3.396e-10, No Iterations 1 DILUPBiCG: Solving for H2O: solution singularity DILUPBiCG: Solving for h, Initial residual = 0.99986, Final residual = 1.0717e-09, No Iterations 2 T gas min/max = 297.98, 298.06 GAMG: Solving for p, Initial residual = 0.00018278, Final residual = 7.4859e-08, No Iterations 16 GAMG: Solving for p, Initial residual = 7.4848e-08, Final residual = 5.6773e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 5.8874e-11, global = -4.1007e-11, cumulative = -9.1089e-09 rho max/min : 1.2053 1.1679 GAMG: Solving for p, Initial residual = 1.5556e-05, Final residual = 6.5459e-08, No Iterations 7 GAMG: Solving for p, Initial residual = 6.5459e-08, Final residual = 6.1625e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 6.3906e-11, global = 2.1691e-11, cumulative = -9.0872e-09 rho max/min : 1.2058 1.1679 GAMG: Solving for p, Initial residual = 1.1122e-06, Final residual = 8.7402e-08, No Iterations 3 GAMG: Solving for p, Initial residual = 8.7402e-08, Final residual = 5.5515e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 5.757e-11, global = 7.2634e-12, cumulative = -9.08e-09 rho max/min : 1.2058 1.1679 GAMG: Solving for epsilon, Initial residual = 0.99999, Final residual = 4.4529e-10, No Iterations 1 bounding epsilon, min: -23.934 max: 71109 average: 1.3766 GAMG: Solving for k, Initial residual = 0.99999, Final residual = 4.4898e-08, No Iterations 70 bounding k, min: -2.2943e+07 max: 3.6509e+08 average: 3191.4 PIMPLE: iteration 3 GAMG: Solving for Ux, Initial residual = 0.72148, Final residual = 2.8168e-08, No Iterations 8 GAMG: Solving for Uy, Initial residual = 0.92796, Final residual = 4.6542e-08, No Iterations 8 GAMG: Solving for Uz, Initial residual = 0.96434, Final residual = 7.2671e-08, No Iterations 8 DILUPBiCG: Solving for H2O: solution singularity DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.023093, No Iterations 2 T gas min/max = 297.98, 298.06 GAMG: Solving for p, Initial residual = 0.0080768, Final residual = 7.9938e-08, No Iterations 28 GAMG: Solving for p, Initial residual = 7.9316e-08, Final residual = 5.7723e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 6.0768e-11, global = -4.0651e-11, cumulative = -9.1206e-09 rho max/min : 1.848 0.96985 GAMG: Solving for p, Initial residual = 0.0019589, Final residual = 7.5856e-08, No Iterations 21 GAMG: Solving for p, Initial residual = 7.5892e-08, Final residual = 5.1389e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 5.4049e-11, global = -3.7593e-11, cumulative = -9.1582e-09 rho max/min : 1.7398 0.94843 GAMG: Solving for p, Initial residual = 0.00036546, Final residual = 7.76e-08, No Iterations 23 GAMG: Solving for p, Initial residual = 7.7608e-08, Final residual = 5.611e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 5.9e-11, global = -4.0674e-11, cumulative = -9.1989e-09 rho max/min : 1.878 0.98689 GAMG: Solving for epsilon, Initial residual = 1, Final residual = 4.5124e-08, No Iterations 9 bounding epsilon, min: -2.6567e+14 max: 9.8944e+14 average: 4.3069e+11 GAMG: Solving for k, Initial residual = 3.1203e-05, Final residual = 3.4191e-08, No Iterations 3 bounding k, min: -0.0028429 max: 1.1084e+08 average: 13164 PIMPLE: iteration 4 GAMG: Solving for Ux, Initial residual = 0.69715, Final residual = 8.8458e-13, No Iterations 1 GAMG: Solving for Uy, Initial residual = 0.66265, Final residual = 5.0469e-13, No Iterations 1 GAMG: Solving for Uz, Initial residual = 0.89007, Final residual = 1.8401e-13, No Iterations 1 DILUPBiCG: Solving for H2O: solution singularity DILUPBiCG: Solving for h, Initial residual = 0.93521, Final residual = 0.060826, No Iterations 1 T gas min/max = -28.694, 299.97 GAMG: Solving for p, Initial residual = 0.17195, Final residual = 7.8752e-08, No Iterations 29 GAMG: Solving for p, Initial residual = 8.8696e-08, Final residual = 6.5726e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 7.5836e-11, global = 5.0269e-11, cumulative = -9.1486e-09 rho max/min : 1.4518 0 GAMG: Solving for p, Initial residual = 0.05066, Final residual = 9.9767e-08, No Iterations 26 GAMG: Solving for p, Initial residual = 1.027e-07, Final residual = 7.4687e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 8.1351e-11, global = -5.5958e-11, cumulative = -9.2046e-09 rho max/min : 1.3965 0 GAMG: Solving for p, Initial residual = 0.016961, Final residual = 8.0106e-08, No Iterations 23 GAMG: Solving for p, Initial residual = 8.0702e-08, Final residual = 5.627e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 6.0392e-11, global = 4.4356e-11, cumulative = -9.1602e-09 rho max/min : 1.3959 0 GAMG: Solving for epsilon, Initial residual = 1, Final residual = 6.2629e-16, No Iterations 1 bounding epsilon, min: -2.2666e+12 max: 4.6152e+10 average: -2.4192e+07 GAMG: Solving for k, Initial residual = 0.99984, Final residual = 1.5475e-11, No Iterations 1 bounding k, min: -2.7051e+07 max: 5.1083e+07 average: 6384.9 PIMPLE: iteration 5 GAMG: Solving for Ux, Initial residual = 0.88859, Final residual = 1.3661e-07, No Iterations 1000 GAMG: Solving for Uy, Initial residual = 0.9647, Final residual = 9.9942e-08, No Iterations 598 GAMG: Solving for Uz, Initial residual = 0.90627, Final residual = 4.0161e-06, No Iterations 1000 DILUPBiCG: Solving for H2O: solution singularity DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.024346, No Iterations 2 [7] [7] [7] --> FOAM FATAL ERROR: [7] Maximum number of iterations exceeded [7] [7] From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar)const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy>] [7] in file /export/opt/openfoam/OpenFOAM-4.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66. [7] FOAM parallel run aborting [7] [7] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [7] #1 Foam::error::abort() at ??:? [7] #2 Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy>::THs(double, double, double) const at ??:? [7] #3 Foam::hePsiThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::calculate() at ??:? [7] #4 Foam::hePsiThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::correct() at ??:? [7] #5 ? at ??:? [7] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [7] #7 ?-------------------------------------------------------------------------- MPI_ABORT was invoked on rank 7 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- at ??:? ^C
@hotairballon1997 先输出cell的坐标,然后根据你的实验数据,或者你profile拟合出来的方程给每个cell一个vector。我之前有个帖子写了方法的
@星星星星晴 非常感谢,确实有用,就相当于手动map了一下入口场
@hotairballon1997 算吧 不过不是map,我个人觉得不要轻易用map这个人东西。。因为网格密度不同,map出来的场可能是有问题的
2019年11月11日 09:30
8/13
2020年10月1日 07:40
