层流RTS调用机制简析(以simpleFoam为例)
注意到simpleFoam源码的createField.H中含有一行代码:
singlePhaseTransportModel laminarTransport(U, phi);将类singlePhaseTransportModel实例化为laminarTransport,并且传给构造函数两个参数U和phi。
在simpleFoam.C中找到了#include "singlePhaseTransportModel.H"。类singlePhaseTransportModel很有可能在里面定义,因此进入singlePhaseTransportModel.H。
其路径为$FOAM_SRC/transportModels/incompressible/singlePhaseTransportModel/singlePhaseTransportModel.H,发现类singlePhaseTransportModel,及其构造函数的声明。因此进入singlePhaseTransportModel.C中查看其定义。Foam::singlePhaseTransportModel::singlePhaseTransportModel ( const volVectorField& U, const surfaceScalarField& phi ) : IOdictionary ( IOobject ( "transportProperties", U.time().constant(), U.db(), IOobject::MUST_READ_IF_MODIFIED, IOobject::NO_WRITE ) ), viscosityModelPtr_(viscosityModel::New("nu", *this, U, phi)) {}在类singlePhaseTransportModel构造前,先建立了读取constant/transportProperties的字典,并用
viscosityModel::New返回了一个叫viscosityModelPtr_的指针。
因此需要查看viscosityModel::New的定义。路径为$FOAM_SRC/transportModels/incompressible/viscosityModels/viscosityModel/viscosityModelNew.C。相关代码如下:Foam::autoPtr<Foam::viscosityModel> Foam::viscosityModel::New ( const word& name, const dictionary& viscosityProperties, const volVectorField& U, const surfaceScalarField& phi ) { const word modelType(viscosityProperties.lookup("transportModel")); Info<< "Selecting incompressible transport model " << modelType << endl; auto cstrIter = dictionaryConstructorTablePtr_->cfind(modelType); if (!cstrIter.found()) { FatalErrorInFunction << "Unknown viscosityModel type " << modelType << nl << nl << "Valid viscosityModels :" << endl << dictionaryConstructorTablePtr_->sortedToc() << exit(FatalError); } return autoPtr<viscosityModel> (cstrIter()(name, viscosityProperties, U, phi)); }此函数本质是在contant/transportProperties文件中查询关键字transportModel对应的值(以Newtonian为例),并在哈希表中查看是否存在这个Newtonian。返回Newtonian在哈希表中对应的值。以我目前的学习经验来看,这个对应值应该是类Newtonian的一个临时对象,并用cstrIter()(name, viscosityProperties, U, phi)括号里的参数进行了初始化。因此需要找到类Newtonian的构造函数。路径为:$FOAM_SRC/transportModels/incompressible/viscosityModels/Newtonian/Newtonian.C
Foam::viscosityModels::Newtonian::Newtonian ( const word& name, const dictionary& viscosityProperties, const volVectorField& U, const surfaceScalarField& phi ) : viscosityModel(name, viscosityProperties, U, phi), nu0_("nu", dimViscosity, viscosityProperties_), nu_ ( IOobject ( name, U_.time().timeName(), U_.db(), IOobject::NO_READ, IOobject::NO_WRITE ), U_.mesh(), nu0_ ) {}在构造类Newtonian时先构造了类viscosityModel。注意到类viscosityModel是类Newtonian的一个父类。因此需要找到类viscosityModel的构造函数。路径为:$FOAM_SRC/transportModels/incompressible/viscosityModels/viscosityModel/viscosityModel.C
Foam::viscosityModel::viscosityModel ( const word& name, const dictionary& viscosityProperties, const volVectorField& U, const surfaceScalarField& phi ) : name_(name), viscosityProperties_(viscosityProperties), U_(U), phi_(phi) {}类viscosityModel的构造函数实际是将形参用于name_,viscosityProperties_,U_和phi_初始化了。这里的viscosityProperties_由于被类Newtonian继承,在类Newtonian的构造函数中可以看见nu0_使用了viscosityProperties_进行初始化。而viscosityProperties_的本质实际就是
IOdictionary ( IOobject ( "transportProperties", U.time().constant(), U.db(), IOobject::MUST_READ_IF_MODIFIED, IOobject::NO_WRITE ) ),返回看nu0_的初始化:
nu0_("nu", dimViscosity, viscosityProperties_)实际是读取constant/transportProperties文件里的nu关键字对应的dimensionedScalar。
而nu_nu_ ( IOobject ( name, U_.time().timeName(), U_.db(), IOobject::NO_READ, IOobject::NO_WRITE ), U_.mesh(), nu0_ )nu_则是以nu0_这个dimensionedScalar构建了一个volScalarField。
