需求是 通过probes,随计算时间步实时输出 目标位置的压力值。
wh3296
动网格 运动浮体表面的压力监测 -
动网格 运动浮体表面的压力监测现在算一个船体运动响应的动网格算例,用probes监测某几处位置(均位于船体外表面)的压力p。
计划算50s,算到22s的时候计算中止。在22s重新提交,发现由于船体运动,0时刻probes的位置在22s时刻 不在流场域了,所以probes的位置都捕捉不到了。。。
这种情况有什么解决方案吗?
求指教。
求助贴:湍流计算遇到一个小问题,求指教@李东岳 解决了,谢谢!
求助贴:湍流计算遇到一个小问题,求指教网格划分好了之后,计算报错。貌似是wall边界条件的问题?还是湍流模型的问题呢?
哪位大佬可以点拨一下,不胜感激!Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST [8] [8] [8] --> FOAM FATAL IO ERROR: [8] Entry 'method' not found in dictionary "IOstream.wallDist" [8] [8] [8] file: IOstream.wallDist [8] [8] From function bool Foam::dictionary::readEntry(const Foam::word&, T&, Foam::keyType::option, bool) const [with T = Foam::word] [8] in file /home/b408/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude/dictionaryTemplates.C at line 334. [8] FOAM parallel run exiting -
动网格算例中,怎样提取结构物表面某点的位移pointDisplacement?@李东岳 好的,我试试这个思路,多谢李老师了!
李老师,我试了下,controlDict文件里是这样写的:functions { { // Line 57 const point A = point[222]; vector = A[222] - A[222].oldtime(); Info << vector; } ........ }运行报错:
Create time [0] [0] [0] --> FOAM FATAL IO ERROR: [0] Found { but expected } [0] [0] file: /home/b408/OpenFOAM/b408-v1912/run_test/DTCHullMoving_t1222_0/system/controlDict at line 57. [0] [0] From function static bool Foam::entry::New(Foam::dictionary&, Foam::Istream&, Foam::entry::inputMode, int) [0] in file db/dictionary/entry/entryIO.C at line 179. [0] FOAM parallel run exiting [0] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- -
动网格算例中,怎样提取结构物表面某点的位移pointDisplacement?@李东岳 这是可以的。我想实现的是 某个位置的位移随每个计算时间步timeStep实时输出。就像controlDict里的function通过probe输出p和U一样。
动网格算例中,怎样提取结构物表面某点的位移pointDisplacement?求助 请教,在包含结构物运动的动网格算例中(例如floatingObject,DTCHullMoving此类),怎样提取结构物表面某一点的位移pointDisplacement?
在controlDict文件中 用Probe尝试过,只能提取U p等,无法提取pointDisplacement。个人猜测原因是:U p是数据记录在网格的场,而pointDisplacement数据记录在节点。
在网上也看了好多关于数据分析和后处理的资料,一直找不到方法。求大神指教!不胜感激! -
OpenFOAM中动网格(或者重叠网格)计算后,怎么提取浮体的位移呢?@五好青年 请问您知道提取位移的方法了吗?遇到了同样的问题,求指导。谢谢!
计算中断后可以根据已输出结果继续计算吗?@cccrrryyy 好的,谢谢!
计算中断后可以根据已输出结果继续计算吗?由于实验室断电,一个正在计算的算例计算中断。瞬态两相流算例,计算时间设置 startTime 为 0 s,endTime为 9 s,输出间隔0.1s,固定时间步长。四核并行。
计算中断时,计算进行到6.56s,输出文件中保留了 0 s 时刻到 6.5 s 时刻的数据。
请问:
我根据输出时间步6.5s的结果数据继续计算(即设置startTime为 6.5 s,endTime为 9 s),这样得到的结果可靠吗?
相比于从0 s 重新计算,两者结果差别大吗?
求大佬指教,谢谢! -
Time step continuity errors: ....cumulative = 1.42075e+40@星星星星晴 好的,多谢啦~
Time step continuity errors: ....cumulative = 1.42075e+40@星星星星晴 但是这个报错是运算了一定时间之后出现的,从0时刻开始计算,计算时间设定38s,一般是18s前后出现报错消息,前17s结果良好。
Time step continuity errors: ....cumulative = 1.42075e+40@星星星星晴 谢谢,那应该就是处理器边界条件了...
Time step continuity errors: ....cumulative = 1.42075e+40@cccrrryyy scotch也不行,也会报错......
Time step continuity errors: ....cumulative = 1.42075e+40@cccrrryyy 好的,我试一下,谢谢!
并行计算出现错误,一直没搞定,求教大神!@xiaohsu2006 请问问题解决了吗?我也遇到了类似的问题。谢谢!
Time step continuity errors: ....cumulative = 1.42075e+40@队长别开枪 刚看了一下,设置都没有问题。不过,昨晚试了下,不并行,单核计算的情况下,一切正常,没有出现发散的情况。所以,是并行导致的问题吗?谢谢!
FoamFile { version 2.0; format ascii; class dictionary; note "mesh decomposition control dictionary"; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // numberOfSubdomains 6; method simple; //method hierarchical; // method simple; // method metis; // method manual; // method multiLevel; // method structured; // does 2D decomposition of structured mesh simpleCoeffs { n (6 1 1); delta 0.001; } -
Time step continuity errors: ....cumulative = 1.42075e+40请问出现这种情况是什么原因呢?
设置Co <1自动调整时间步长,而Co数还比较小,但是时间步长却已经很小了。如下图所示。
这个时间步之前都很正常(如下图所示):
请问是什么原因呢?谢谢!
