@李东岳 感谢东岳老师提供的思路,我在代码中把ShihQuadraticKE改了个名,目前在源文件中用Allwmake编译成功了。
不过孩子还是很不明白怎么单独拿出来编译这类非线性湍流模型,看来暂时只能通过这种方式代替了。
EZY
非线性涡粘性模型编译问题 -
非线性涡粘性模型编译问题问题描述
各位前辈和同学们大家好,我最近在尝试在基于k-epsilon的涡粘性模型中加入非线性项的影响,于是在OpenFoam中找到了一些非线性涡粘性模型如下
使用的OpenFoam版本为com版的OpenFOAM-v2012看到ShihQuadraticKE的方程和我想要的形式比较契合,于是乎便考虑对ShihQuadraticKE进行修改后尝试编译一个新的湍流模型,我准备的文件如下
files、options和maketurbulentTransportModels.C代码如下
files:maketurbulentTransportModels.C LIB = $(FOAM_USER_LIBBIN)/NonlinearEVM/libNonlinearKE_TESToptions:
EXE_INC = \ -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \ -I$(LIB_SRC)/TurbulenceModels/incompressible/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/transportModels LIB_LIBS = \ -lturbulenceModels \ -lfiniteVolume \ -lmeshTools \ -lincompressibleTransportModelsmaketurbulentTransportModels.C:
#include "turbulentTransportModels.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defineTurbulenceModelTypes ( geometricOneField, geometricOneField, incompressibleTurbulenceModel, IncompressibleTurbulenceModel, transportModel ); makeBaseTurbulenceModel ( geometricOneField, geometricOneField, incompressibleTurbulenceModel, IncompressibleTurbulenceModel, transportModel ); #include "nonlinearEVM_TEST.H" makeRASModel(nonlinearEVM_TEST);nonlinearEVM_TEST.C和nonlinearEVM_TEST.C都和ShihQuadraticKE源码一样
但是wmake编译后出现了这样的错误:In file included from /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/typeInfo.H:60:0, from /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/token.H:49, from /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/UILListIO.C:31, from /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/UILList.H:462, from /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/ILList.H:42, from /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/IDLList.H:37, from /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/entry.H:48, from /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/dictionary.H:92, from /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/baseIOdictionary.H:46, from /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/IOdictionary.H:44, from /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/TurbulenceModels/turbulenceModels/lnInclude/turbulenceModel.H:44, from /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/TurbulenceModels/turbulenceModels/lnInclude/TurbulenceModel.H:40, from IncompressibleTurbulenceModel.H:42, from turbulentTransportModels.H:28, from maketurbulentTransportModels.C:28: turbulentTransportModels.H:54:51: error: ‘Foam::RASModels’ has not been declared (transportModelIncompressibleTurbulenceModel, RAS, Type) ^ /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/className.H:93:24: note: in definition of macro ‘defineTypeNameWithName’ const ::Foam::word Type::typeName(Name) ^~~~ /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/className.H:114:5: note: in expansion of macro ‘defineTemplateTypeNameWithName’ defineTemplateTypeNameWithName(Type, Type::typeName_()) ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/className.H:137:5: note: in expansion of macro ‘defineNamedTemplateTypeName’ defineNamedTemplateTypeName(Type); \ ^~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/TurbulenceModels/turbulenceModels/lnInclude/makeTurbulenceModel.H:116:5: note: in expansion of macro ‘defineNamedTemplateTypeNameAndDebug’ defineNamedTemplateTypeNameAndDebug \ ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ turbulentTransportModels.H:53:5: note: in expansion of macro ‘makeTemplatedTurbulenceModel’ makeTemplatedTurbulenceModel \ ^~~~~~~~~~~~~~~~~~~~~~~~~~~~ maketurbulentTransportModels.C:53:1: note: in expansion of macro ‘makeRASModel’ makeRASModel(nonlinearEVM_TEST); ^ /home/ezylinux/OpenFOAM/OpenFOAM-v2012/src/TurbulenceModels/turbulenceModels/lnInclude/makeTurbulenceModel.H:117:35: error: expected initializer before ‘<’ token (Foam::SType##Models::Type<Foam::BaseModel>, 0); ......后面比较长,但都是差不多一样的,我感觉主要的问题出在这一句
turbulentTransportModels.H:54:51: error: ‘Foam::RASModels’ has not been declared首先报错的地方在
turbulentTransportModels.H的54行,说Foam::RASModels没有被声明
我的认识和思路
我对OF代码架构的了解十分有限,并不是很清楚这句话意味着什么,但循着这条线索走下去,我还是发现了一些可能相关的原因,在我这个版本的OF中,RANS湍流模型的架构是这样的
因为我之前对此版本的标准kEpsilon模型成功进行修改和编译过,说明我编译湍流模型的流程应该没啥结构性问题。因此从这点出发,我对比了kEpsilon和ShihQuadraticKE源码的差别,大致查看了
kEpsilon.H可以发现,kEpsilon类的位置在这里Foam::RASModelsnamespace Foam { namespace RASModels { template<class BasicTurbulenceModel> class kEpsilon : public eddyViscosity<RASModel<BasicTurbulenceModel>> ......kEpsilon类通过makeRASModel(kEpsilon)实现模板特化,这也与前面maketurbulentTransportModels.C最后两行代码对应。而在
ShihQuadraticKE.H中可以发现ShihQuadraticKE的位置在这里Foam::incompressible::RASModelsnamespace Foam { namespace incompressible { namespace RASModels { class ShihQuadraticKE : public nonlinearEddyViscosity<incompressible::RASModel> ......这就和
kEpsilon的声明不同了,根据OpenFOAM之道上的解释
再结合前面的error: ‘Foam::RASModels’ has not been declared错误提示,我就在想是不是因为kEpsilon和ShihQuadraticKE继承关系的差别导致这个错误呢?
详见此图:RANSModel的继承关系
maketurbulentTransportModels.C中的makeRASModel(Type)是不是也不能这样用了呢?因为在turbulentTransportModels.C源码中的RANS模型全都是src\TurbulenceModels\turbulenceModels\RAS中的,没有ShihQuadraticKE这些非线性模型困惑与总结
可是我编译的文件
files、options和maketurbulentTransportModels.C中也没有涉及到继承关系的代码,我不知道该从哪里改起了,这个问题困扰我好久了没有进度,在本站,cfd-online等网站上也没找到相关问题。
总之,此贴主要可以归结为一句话:
src\TurbulenceModels\incompressible\turbulentTransportModels\RAS目录下的RANS模型(类的位置Foam::incompressible::RASModels)应该如何编译,与src\TurbulenceModels\turbulenceModels\RAS下的RANS模型(类的位置Foam::RASModels)编译时有何区别? -
《无痛苦N-S方程笔记》勘误?小弟最近在看一些非线性涡粘性模型,发现在笔记2022.10.20最新修订版的第95页处,湍动能产生项的表达式写为
然而在看OF中源码时发现有点对不上
τn作为应力项其量纲应与 νt*2Sij一致才对,所以这里应该少了一个括号。
也就是
我应该没看漏吧
